2. Linear motion ​
1. Linear Motion ​
Initialization ​
Assume the robotic arm controller's IP address is 192.168.1.47, initialize the robotic arm.
arm=XArmAPI('192.168.1.47')
Enable ​
If the robotic arm is not enabled, it needs to be enabled. Once enabled, there is no need to enable it again.
Set Mode and State ​
After enabling, you need to set the mode and state for the robotic arm to move.
The robotic arm has multiple modes; the commonly used linear motion and joint motion are both position commands, i.e., mode 0.
arm.set_mode(0)
The robotic arm can be set to various modes. Mode 0 is for motion, mode 3 is for pausing the motion, and mode 4 is for stopping the motion.
Send Position Command ​
In the xArm-Python-SDK, the Cartesian position is defined as x, y, z, roll, pitch, yaw.
The unit for distance is millimeters (mm), and the default angle representation is degrees (°).
As an example of linear motion in Cartesian space, let the robotic arm move to point A [300,0,150,180,0,0] first, and then to point B [400,0,150,180,0,0].
arm.set_position(300,0,150,180,0,0)
arm.set_position(400,0,150,180,0,0)
Speed ​
In the set_position() interface for linear motion, the speed is passed with the speed parameter, and the unit is mm/s.
For example, let the robotic arm move to point A [300,100,150,180,0,0] at 200 mm/s.
arm.set_position(300,100,150,180,0,0, speed=200)
Complete Example ​
arm = XArmAPI('192.168.1.47')
arm.set_mode(0)
arm.set_position(300,0,150,180,0,0, speed=200)
arm.set_position(400,0,150,180,0,0, speed=200)
