System State(11-20) ​
Enable/Disable servo (System reset) ​
Register:11(0x0B)
warning:
The above operations will terminate the ongoing movement of the robotic arm and clear the cache commands, which is the same as the STOP state.
00 01 00 02 00 03 0B 08 01
Request Description
//00 03 U16, Length
//0B U8, Register
//08 U8,
Joint Number(Select all joints)
1-7:Motor joint(1-7)
8:Select all joint
//01 U8,
Whether to enable the servo
1:Enable servo
0:Disable servo
00 01 00 02 00 02 0B 10
Response Description
//00 02 U16, Length
//0B U8, Register
//10 U8, State
Motion state setting ​
Register:12(0x0C)
00 01 00 02 00 02 0C 00
Request Description
//00 02 U16, Length
//0C U8, Register
//00 U8,
Motion Sate
0: Enter the motion mode
3: Suspend the current motion(Do not clear controller cache)
4: Stop all current motion (restart the system,clear controller cache)
//00 02 U16, Length
//0C U8, Register
Get the motion state ​
Register:13 (0x0D)
00 01 00 02 00 01 0D
Request Description
//00 01 U16, Length
//0D U8, Register
00 01 00 02 00 03 0D 00 02
//00 01 U16, Length
//0D U8, Register
//02 U8,
Motion state:
1:In motion
2:Sleep
3:Suspend
4:Stop
5: System reset
Get the number of commands in the command buffer ​
Register:14 (0x0E)
00 01 00 02 00 01 0E
Request Description
//00 01 U16, Length
//0E U8, Register
00 01 00 02 00 04 0E 00 00 00
//00 04 U16, Length
//0E U8, Register
//00 00 U16, The number of commands in the buffer
Get error and warning code ​
Register:15 (0x0F)
00 01 00 02 00 01 0F
Request Description
//00 01 U16, Length
//0F U8, Register
00 01 00 02 00 04 0F 00 00 00
//00 04 U16, Length
//0F U8, Register
//00 U8, Error code
//00 U8, Warning code
Clear control box error (System reset) ​
Register:16 (0x10)
warning:
00 01 00 02 00 01 10
Request Description
//00 01 U16, Length
//10 U8, Register
00 01 00 02 00 02 10 00
//00 02 U16, Length
//10 U8, Register
Clear control box warning ​
Register:17 (0x11)
00 01 00 02 00 01 11
Request Description
//00 01 U16, Length
//11 U8, Register
00 01 00 02 00 02 11 00
//00 02 U16, Length
//11 U8, Register
Setting the brake switches separately (System reset) ​
Register:18 (0x12)
00 01 00 02 00 03 12 08 01
Request Description
//00 03 U16, Length
//12 U8, Register
//08 U8, 1~6: Select motor joint separately 8: Select all joints
//01 U8, 0: Disable Joint 1: Unlock Joint
00 01 00 02 00 02 12 10
//00 02 U16, Length
//12 U8, Register
//10 U8, State
Setting the system motion mode (System reset) ​
Register:19 (0x13)
warning:
This operation will terminate the ongoing movement of the robot and clear the cache commands, which is the same as the STOP state.
00 01 00 02 00 03 13 00 00
Request Description
//00 03 U16, Length
//13 U8, Register
//00 U8, Motion mode
0: Position control mode
1: Servo motion mode
2: Joint teaching mode (manual mode)
3: Cartesian teaching mode (not yet available)
4: Joint velocity control mode
5: Cartesian velocity control mode
6: Joint online trajectory planning mode
7: Cartesian online trajectory planning mode
//00 U8, Payload detection before enabling manual mode. 0 is ON, 1 is OFF.
00 01 00 02 00 02 13 00
//00 02 U16, Length
//13 U8, Register
