6. End Effectors ​
API List ​
Vacuum Gripper ​
API FunctionDescription
set_vacuum_gripper()Set vacuum gripper to pick or release
get_vacuum_gripper()Get vacuum gripper state
UFACTORY Gripper ​
set_gripper_enable()Enable the gripper
set_gripper_speed()Set gripper speed
set_gripper_position()Control gripper position
get_gripper_position()Get current gripper position
get_gripper_err_code()Get gripper error code
clean_gripper_error()Clear gripper error
BIO Gripper ​
set_bio_gripper_enable()Enable BIO gripper
set_bio_gripper_speed()Set BIO gripper speed
open_bio_gripper()Open BIO gripper
close_bio_gripper()Close BIO gripper
get_bio_gripper_status()Get BIO gripper status
get_bio_gripper_error()Get BIO gripper error code
clean_bio_gripper_error()Clear BIO gripper error
Robotiq Gripper (2F-85 and 2F-140) ​
set_robotiq_gripper_enable()Enable Robotiq gripper
set_robotiq_gripper_speed()Set Robotiq gripper speed
set_robotiq_gripper_force()Set Robotiq gripper force
open_robotiq_gripper()Open Robotiq gripper
close_robotiq_gripper()Close Robotiq gripper
get_robotiq_gripper_status()Get Robotiq gripper status
End Effector Control ​
Vacuum Gripper ​
Set Vacuum Gripper State ​
Use set_vacuum_gripper(on, wait=False, timeout=3, hardware_version=1) to set the vacuum gripper to pick or release.
  • on: True to pick, False to release.
  • wait: Whether to wait for the picking result. Default is False. If True, the program blocks until the pick succeeds or times out.
  • timeout: Timeout in seconds, default is 3. Takes effect when wait=True. If picking fails within the specified time (determined by the vacuum gripper's built-in pressure sensor), the SDK returns error code 41.
  • hardware_version: Hardware version.
    • 1: Plug-in connection (default)
    • 2: PIN contact connection
Example:
# Simply turn on and off, vacuum gripper is plug-in connnetion
arm.set_vacuum_gripper(True)   # Pick
time.sleep(2)
arm.set_vacuum_gripper(False)  # Release
# Wait for the result, up to 3 seconds
code = arm.set_vacuum_gripper(True, wait=True, timeout=3)
if code == 0:
    print("Picked successfully")
else:
    print(f"Pick failed, code: {code}")
Get Vacuum Gripper State ​
Use get_vacuum_gripper() to get the current state of the vacuum gripper.
    • 1: Aviation connector (default)
    • 2: PIN contact connector
  • Return Value: A tuple containing the error code and state.
    • code: API return code
    • state: Gripper state
      • 0: Off
      • 1: On
Example:
code, state = arm.get_vacuum_gripper()
if code == 0:
    if state == 1:
        print("Vacuum gripper is on")
    else:
        print("Vacuum gripper is off")
UFACTORY Gripper ​
Enable Gripper ​
Enable the gripper before use.
# Enable gripper
arm.set_gripper_enable(True)
Set Gripper Speed ​
Set the opening/closing speed of the gripper.
# Set gripper speed to 2000
arm.set_gripper_speed(2000)
Control Gripper Position ​
The position range is -10 to 850.
# Open the gripper (fully open)
arm.set_gripper_position(850, wait=True)
# Close the gripper
arm.set_gripper_position(0, wait=True)
wait=True means the program waits for the gripper to reach the position before executing the next command.
