UF_ModbusTCP_Manual ​
UFACTORY ModbusTCP User Instructions ​
Notice: ​
  • Communication complies with standard Modbus TCP protocol
  • Data transmission uses Big-endian method, for example transmission order of data 0x1234 is: 0x12, 0x34
  • Different register addresses hold different specific contents, details refer to the appendix
  • Make sure to access the pre-defined register address(refer to appendix),or there will be exception in response
Supported Modbus TCP function codes: ​
  • Coil register(1 bit)
    • 0x01: Read multiple coil registers,each bit in responded data section represents the value of each one register:
      C++
      // sample request and response / exception
      // Request: Read consecutive 16 registers starting from address 0x0000
      00 01 00 00 00 06 01 01 00 00 00 10
      // Response: every bit in the Received data (0xF7 0x00 here as an example) represents the corresponding register value in order
      00 01 00 00 00 05 01 01 02 F7 00
      // Exception: XX is the exception code
      00 01 00 00 00 03 01 81 XX
    • 0x05: Write single coil, according to Modbus protocol, specified data can only be 0xFF00 or 0x0000,for wriring 1 or 0 to the register.
      C++
      // Request: Write 1 to register address 0x0002 (0xFF00 for writing 1, 0x0000 for writing 0)
      00 01 00 00 00 06 01 05 00 02 FF 00
      00 01 00 00 00 03 01 85 XX
    • 0x0F: Write multiple coil registers
      C++
      // Request: write 3 registers starting from address 0x0002, 0x07 in binary form is for writing all 1s in the three registers.
      00 01 00 00 00 08 01 0F 00 02 00 03 01 07
      00 01 00 00 00 06 01 0F 00 02 00 03
      00 01 00 00 00 03 01 8F XX
  • Discrete input register (1 bit)
    • 0x02: Read multiple discrete input registers
      C++
      // Request: Read 16 consecutive registers from address 0x0000
      00 01 00 00 00 06 01 02 00 00 00 10
      // Response:: every bit in the Received data (0xFF 0x00 here as an example) represents the corresponding register value in order
      00 01 00 00 00 05 01 02 02 FF 00
      00 01 00 00 00 03 01 82 XX
  • Holding register (16 bit)
    • 0x03: Read multiple holding registers
      C++
      // Request: read 2 consecutive holding registers starting from address 0x0003
      00 01 00 00 00 06 01 03 00 03 00 02
      // Response:: Received values of the two registers are (00 05) and (00 06) as an example here
      00 01 00 00 00 07 01 03 04 00 05 00 06
      00 01 00 00 00 03 01 83 XX
    • 0x06: Write single holding register
      C++
      // Request: Write 0x0006 to register address 0x0020
      00 01 00 00 00 06 01 06 00 20 00 06
      00 01 00 00 00 03 01 86 XX
    • 0x10: Write multiple holding registers
      C++
      // Request: Write consecutive 2 registers from address 0x0003
      // the written values are (04 D2) and (0D 80), with corresponding decimal values of 1234 and 3456
      00 01 00 00 00 0B 01 10 00 03 00 02 04 04 D2 0D 80
      00 01 00 00 00 06 01 10 00 03 00 02
      00 01 00 00 00 03 01 90 XX
    • 0x16: Mask write single holding register
      C++
      // Request: write to register address of 0x0000 with mask.
      // "AND" operation mask is (00 0F),"OR" operation mask is (0F 00)
      // If the value before this operation is "val", then after the mask opeation it becomes: (val & 0x000F) | (0x0F00 & ~0x000F)
      00 04 00 00 00 08 01 16 00 00 00 0F 0F 00
      00 01 00 00 00 03 01 96 XX
    • 0x17: Read and Write multiple holding registers
      C++
      // Request: Write 2 registers from address 0x0020, and read 2 registers from address 0x0003
      // values to be written are (00 06) and (00 04)
      00 01 00 00 00 0F 01 17 00 03 00 02 00 20 00 02 04 00 06 00 04
      // Response:  Received values of the two registers are (04 D1) and (0D 7F) as an example here
      00 01 00 00 00 07 01 17 04 04 D1 0D 7F
      00 01 00 00 00 03 01 97 XX
  • Input register (16 bit)
    • 0x04: Read multiple input registers
      C++
      // Request: read 2 consecutive holding registers from address 0x0003
      00 01 00 00 00 06 01 04 00 03 00 02
      // Response: Received 2 values are (00 0E) and (00 13) as an example
      00 01 00 00 00 07 01 04 04 00 0E 00 13
      00 01 00 00 00 03 01 84 XX
Exception code explanation ​
  • 0x01: Illegal/Unsuppported function code
  • 0x02: Illegal target address
  • 0x03: Exception of requested data
Appendix ​
  • Coil Registers (single bit access, READ/WRITE)
    Address(Dec)Address(Hex)Explanation
    0 ~ 310x00 ~ 0x1F32 controller Digital Output (Now only 16 effective)
    32 ~ 390x20 ~ 0x278 tool Digital Output (Now only 2 effective)
    40 ~ 1270x28 ~ 0x7FReserved
    128 ~ 1340x80 ~ 0x86joint (J1-J7) brake states
    135 ~ 1410x87 ~ 0x8Djoint (J1-J7) enable states
    1420x8EReduced mode (0: OFF, 1: ON)
    1430x8FDigital Fence (0: OFF, 1: ON)
    1440x90isPaused (0: False, 1: True)
    1450x91isStopped (0: False, 1: True)
    146 ~ 1590x92 ~ 0x9FRobot Mode (14 bits for mode 0-13 respectively, 0: not in this mode, 1: in this mode)
    160 ~ 2550xA0 ~ 0xFFReserved
    256 ~ 5110x100 ~ 0x1FFGeneral purpose, user defined
  • Discrete Input Registers (single bit access, READ only)
    0 ~ 310x00 ~ 0x1F32 controller Digital Input (Now only 16 effective)
    32 ~ 390x20 ~ 0x278 tool Digital Input (Now only 2 effective)
  • Holding Registers (16 bit access, READ/WRITE)
    0 ~ 10x00 ~ 0x0132 controller Digital Outputs (Now only 16 effective), each bit correspond to one IO in order
    20x028 tool Digital Outputs (Now only 2 effective), each bit correspond to one IO in order
    3 ~ 60x03 ~ 0x064 controller analog outputs (now only 2 effective), it is 1000 times the real value
    7 ~ 100x07 ~ 0x0A4 tool analog outputs (currently NOT EFFECTIVE), it is 1000 times the real value
    11 ~ 310x0B ~ 0x1FReserved
    320x20Robot Mode
    330x21Robot State
    34 ~ 470x22 ~ 0x2FReserved
    48 ~ 630x30 ~ 0x3FOffline (Blockly) Task (only effective by writing multiple (max 16) holding registers to address 0x30 via function code 0x10, each register value correspond to one Blockly project with specific naming convention, for example: value 1 for project '00001', 12 for project '00012', projects will be executed automatically in order)
    640x40Gcode(Firmware≥2.4.0), trigged the gcode file under modbus_tcp folder.
    65 ~ 2550x41 ~ 0xFFReserved
  • Input Registers (16 bit access, READ only)
    0 ~ 10x00 ~ 0x0132 controller Digital Inputs (Now only 16 effective)
    20x028 tool Digital Inputs (Now only 2 effective)
    3 ~ 60x03 ~ 0x064 controller analog inputs (now only 2 effective), it is 1000 times the real value
    7 ~ 100x07 ~ 0x0A4 tool analog inputs (now only 2 effective), it is 1000 times the real value
    320x20Robot Error code
    330x21Robot Warning code
    34 ~ 350x22 ~ 0x23Counter value (0x22 stores the higher 16-bit, 0x23 stores the lower 16-bit)
    36 ~ 630x23 ~ 0x3FReserved
    64 ~ 720x40 ~ 0x48Current TCP coordinate of x/y/z/roll/pitch/yaw/rx/ry/rz values, register values are 10 times the real numbers (unit: mm, degree)
    73 ~ 760x49 ~ 0x4CTCP payload mass(1000x)/center_x(10x)/center_y(10x)/center_z(10x) (unit: kg, mm)
    77 ~ 820x4D ~ 0x52TCP Offset, register values are 10 times the real numbers(unit: mm, degree)
    83 ~ 880x53 ~ 0x58User/world coordinate offset, register values are 10 times the real numbers(unit: mm, degree)
    89 ~ 950x59 ~ 0x5Fjoint (J1-J7) angles, register values are 10 times the real numbers(unit: degree)
    86 ~ 1020x60 ~ 0x66joint (J1-J7) temperature (unit: degree Celsius)
    103 ~ 1090x67 ~ 0x6Djoint (J1-J7) speed, register values are 10 times the real numbers(unit: degree/s)
    1100x6ERobot TCP linear speed, register values are 10 times the real numbers(unit: mm/s)
    111 ~ 1270x6F ~ 0x7FReserved
