Modbus RTU Slave: How to Read and Write Controller Output CO ​
1. Scenario Description ​
  • Device: xArm Controller (AC1320 or later, AC8520 or later)
  • Firmware: V2.7.104 or later
  • Communication: Modbus RTU
  • Device Role: Slave
  • Target Function:
    • CO0 -> Low level
    • CO1 -> High level
    • CO2 -> High level
    • CO3 -> Low level
2. Mapping Between Coils and CO ​
Modbus Coil AddressController CODescription
0000CO0Controller Output 0
0001CO1Controller Output 1
0002CO2Controller Output 2
0003CO3Controller Output 3
3. Modbus RTU Command Examples (Function Code 0x0F) ​
3.1 Setting CO ​
Raw Command Frame (HEX) ​
text
01 0F 00 00 00 04 01 06 BE 94
Command Structure Breakdown
text
Slave Address: 01 (1)
Function Code: 0F
Start Address: 00 00 (0000)
Number of Coils: 00 04 (4)
Byte Count: 01 (1)
Data Field:
  Byte 0: 06 (bit0:0, bit1:1, bit2:1, bit3:0)
CRC: BE 94
Response Frame (HEX) ​
text
01 0F 00 00 00 04 54 08
text
Function Code: 0F
Start Address: 00 00 (0)
CRC: 54 08
3.2 Reading CO ​
text
01 01 00 00 00 04 3D C9
text
Function Code: 01
Quantity: 00 04 (4)
CRC: 3D C9
text
01 01 01 06 D1 8A
text
Function Code: 01
Byte Count: 01 (1)
Data Field:
CRC: D1 8A
