5. IO ​
API List ​
IO ​
The IO of the xArm series robots is divided into two parts: controller box IO and robot arm IO.
API FunctionDescription
set_cgpio_digital()Set controller box digital IO output
get_cgpio_digital()Get controller box digital IO input
set_cgpio_analog()Set controller box analog IO output
get_cgpio_analog()Get controller box analog IO input
set_cgpio_digital_input_function()Set the function of the controller's digital input
set_cgpio_digital_output_function()Set the function of the controller's digital output
set_tgpio_digital()Set the end-effector digital IO output
get_tgpio_output_digital()Get the end-effector digital IO output
get_tgpio_digital()Get the end-effector digital IO input
get_tgpio_analog()Get the end-effector analog input
Controller Box IO ​
The controller box IO is located on the controller and is usually used for signal interaction with external devices such as PLCs and sensors.
Set Controller Box Digital Output ​
Use set_cgpio_digital(io_num, value) to set the output level of a controller box digital IO port.
  • io_num: IO port number, range 0-15 (0-7 for Lite 6).
  • value: IO level, 0 for low, 1 for high.
Example: Set controller IO 7 high.
arm.set_cgpio_digital(7, 1)
Get Controller Box Digital Input ​
Use get_cgpio_digital() to obtain the input levels of all controller box digital IO ports. The return value is a tuple containing the error code and IO values.
Example: Get and print the status of all controller box digital inputs.
code, digitals = arm.get_cgpio_digital()
if code == 0:
    print("Controller box digital input status:", digitals)
Set Controller Box Analog Output ​
Use set_cgpio_analog(io_num, value) to set the value of a controller box analog IO.
  • io_num: Analog IO port number, typically 0 or 1.
  • value: Analog value to set, range 0-10.0 (volts).
Example: Set controller analog output AO 0 to 5.0V.
arm.set_cgpio_analog(0, 5.0)
Get Controller Box Analog Input ​
Use get_cgpio_analog() to get the value of a controller box analog IO.
  • io_num: Analog IO port number, 0 or 1.
Example: Get the value of controller analog input CI0.
code, analog_val = arm.get_cgpio_analog(0)
if code == 0:
    print("Controller box analog input 0 value:", analog_val)
Robot Arm IO ​
The robot arm IO (tool IO) functions and APIs are similar to the controller box IO:
IO TypeAPI FunctionDescription
Digital Output (DO)set_tgpio_digital()Set tool digital output level
Digital Input (DI)get_tgpio_digital()Get tool digital input level
Analog Input (AI)get_tgpio_analog()Get tool analog input value
Set Controller Box Digital Input Function ​
Use set_cgpio_digital_input_function(ionum, fun) to configure the function of a controller box digital input port.
  • ionum: IO port number, range 0-15.
  • fun: Function mode:
    • 0: General Input
    • 1: Stop Motion
    • 2: Protection Reset
    • 11: Offline Task
    • 12: Manual Mode
    • 13: Reduced Mode
    • 14: Enable Robot
Example: Configure digital input CI0 to stop motion. When CI0 receives a signal, the robot stops immediately and clears buffered commands, equivalent to set_state(4) without cutting power.
# Configure CI0 (ionum=0) as external emergency stop (fun=1)
arm.set_cgpio_digital_input_function(0, 1)
# Restore CI0 to general input
arm.set_cgpio_digital_input_function(0, 0)
Set Controller Box Digital Output Function ​
Use set_cgpio_digital_output_function(ionum, fun) to configure the function of a controller box digital output port.
  • ionum: IO port number, 0-7 for CO0~CO7 and 8-15 for DO0~DO7.
    • 0: General Output
    • 1: Motion Stop
    • 2: Moving
    • 11: Has Error
    • 12: Has Warn
    • 13: Collision
    • 14: In Manual Mode
    • 15: In Offline Task
    • 16: In Reduced Mode
    • 17: Robot Is Enabled
    • 18: Emergency Stop is Pressed
Example: Configure digital output CO0 to indicate a robot error. When the robot reports an error, CO0 outputs high level.
# Configure CO0 (ionum=0) to indicate error state (fun=11)
arm.set_cgpio_digital_output_function(0, 11)
# Restore CO0 to general output
arm.set_cgpio_digital_output_function(0, 0)
