Other Robotic Arm Function(51-70) ​
Set the gravity direction ​
Register:51 (0x33)
warning
Set the gravity direction for correct torque compensation and collision detection. After modification, it shall call the save_conf () function or refer to Register: 40(28) to save the setting, otherwise it will be invalid after reboot.
00 01 00 02 00 0D 33 00 00 00 00 00 00 00 00 00 00 80 BF
Request Description
//00 0D U16, Length
//33 U8, Register
//00 00 00 00 FP32, Gravity direction vector X=0 base coordinate system
//00 00 00 00 FP32, Gravity direction vector Y=0 base coordinate system
//00 00 80 BF FP32, Gravity direction vector Z=-1 base coordinate system
00 01 00 02 00 02 33 10
Response Description
//00 02 U16, Length
//33 U8, Register
//10 U8, State
Set the safe boundary ​
Register:52 (0x34)
warning
C35 Set the boundary range of the safety fence in the three-dimensional space. If TCP of the robotic arm exceeds this boundary, error C35 of the Control Box will be triggered.
00 01 00 02 00 19 34 58 02 00 00 C8 00 00 00 F4 01 00 00 64 00 00 00 58 02 00 00 C8 00 00 00
Request Description
//00 19 U16, Length
//34 U8, Register
//58,02,00,00 FP32, Cartesian boundary value x+ =600 mm
//C8,00,00,00 FP32, Cartesian boundary value x- =200 mm
//F4,01,00,00 FP32, Cartesian boundary value y+ =500 mm
//64,00,00,00 FP32, Cartesian boundary value y- =100 mm
//58,02,00,00 FP32, Cartesian boundary value z+ =600 mm
//C8,00,00,00 FP32, Cartesian boundary value z- =200 mm
00 01 00 02 00 02 34 10
//00 02 U16, Length
//34 U8, Register
//10 U8, State
Get all configurations of the Reduced Mode ​
Register:53 (0x35)
00 01 00 02 00 01 35
Request Description
//00 01 U16, Length
//35 U8, Register
00 01 00 02 00 51 35 00 01 01 2C 00 64 01 2C FF F6 01 2C 00 32 00 00 C8 42 DB 0F 49 40 DB 0F C9 C0 DB 0F C9 40 15 C6 03 C0 91 0A 06 40 CE 53 7B C0 68 96 44 3E DB 0F C9 C0 DB 0F C9 40 35 B3 D8 BF DB 0F 49 40 DB 0F C9 C0 DB 0F C9 40 00 00 00 00 00 00 00 00 01 01
//00 51    U16, Length
//35       U8, Register
//10       U8, State
//10       U8, State
//00	   U16,	The state of Reduce mode: 0-OFF; 1-ON
//01 2C 00 64  01 2C FF F6 01 2C 00 32
int16*6, safety boundary
[x_max=300, x_min=100, y_max=300, y_min=-10, z_max=300, z_min=50]
//00 00 C8 42 FP32, Max TCP speed=100mm/s
//DB 0F 49 40 FP32, max Joint speed=180 °/s
//DB 0F C9 C0 DB 0F C9 40 15 C6 03 C0 91 0A 06 40 CE 53 7B C0 68 96 44 3E DB 0F C9 C0 DB 0F C9 40 35 B3 D8 BF DB 0F 49 40 DB 0F C9 C0 DB 0F C9 40 00 00 00 00 00 00 00 00
FP32*7, Joint range: [J1_min, J1_max, …, J7_min, J7_max]
//01  U8, The state of Safety Boundary: 0- OFF; 1-ON
//01  U8, The state of Collision Rebound: 0- OFF; 1-ON
Get the current of each joint ​
Register:55 (0x37)
warning
Estimate the joint torque based on current and theoretical model, which is for reference only
00 01 00 02 00 01 37
Request Description
//00 01 U16, Length
//37 U8, Register
00 01 00 02 00 1E 37 00 17 37 00 00 00 00 00 2A C5 5B C1 79 A4 C5 C0 00 00 00 00 87 A3 E9 BF 00 00 00 00 00 00 00 00
//00 1E U16, Length
//37 U8, Register
//00 00 00 00 FP32, Theoretical torque of joint1 = 0
//2A C5 5B C1 FP32, Theoretical torque of joint2 = -13.7 N.m
//79 A4 C5 C0 FP32, Theoretical torque of joint3 = -6.17 N.m
//00 00 00 00 FP32, Theoretical torque of joint4 = 0
//87 A3 E9 BF FP32, Theoretical torque of joint5 = -1.83N.m
//00 00 00 00 FP32, Theoretical torque of joint6 = 0
//00 00 00 00 FP32, Theoretical torque of joint7 = 0
Set Joint Range Limit of Reduced Mode ​
Register:58 (0x3A)
00 01 00 02 00 39 3A C2 F5 48 C0 C2 F5 48 40 33 33 03 C0 8F C2 05 40	C2 F5 48 C0 C2 F5 48 40 5C 8F 42 BE 47 E1 7A 40 C2 F5 48 C0 C2 F5 48 40 EB 51 D8 BF C8 00 00 00 C2 F5 48 C0 C2 F5 48 40
Request Description
//00 39 U16, Length
//3A U8, Register
//C2 F5 48 C0 C2 F5 48 40 FP32, J1_min = -3.14rad,J1_max = 3.14rad
//33 33 03 C0 8F C2 05 40 FP32, J2_min = -2.05rad,J2_max = 20.9rad
//C2 F5 48 C0 C2 F5 48 40 FP32, J3_min = -3.14rad,J3_max = 3.14rad
//5C 8F 42 BE 47 E1 7A 40 FP32, J4_min = -0.19rad,J4_max = 3.92rad
//C2 F5 48 C0 C2 F5 48 40 FP32, J5_min = -3.14rad,J5_max = 3.14rad
//EB 51 D8 BF C8 00 00 00 FP32, J6_min = -1.69rad,J6_max = 3.14rad
//C2 F5 48 C0 C2 F5 48 40 FP32, J7_min = -3.14rad,J7_max = 3.14rad
00 01 00 02 00 02 3A 00
//00 02 U16, Length
//3A U8, Register
Safety boundary switch ​
Register: 59 (0x3B)
warning
Set the safety boundary in three-dimensional space. If the TCP of the robot exceeds this boundary, error C35 will be triggered.
00 01 00 02 00 02 3B 00
Request Description
//00 02 U16, Length
//3B U8, Register
//00 U8, 0: Disable safety boundary. 1: Enable safety boundary.
//00 02 U16, Length
//3B U8, Register
Set the state of Collision Rebound ​
Register:60 (0x3C)
00 01 00 02 00 02 3C 00
Request Description
//00 02 U16, Length
//3C U8, Register
//00 U8, Collision Rebound switch 0-OFF; 1-ON
00 01 00 02 00 02 3C 10
//00 02 U16, Length
//3C U8, Register
Start/Stop trajectory record ​
Register:61 (0x3D)
00 01 00 02 00 02 3D 00
Request Description
//00 02 U16, Length
//3D U8, Register
//00 U8, 0-Stop trajectory record, 1-start trajectory record
//00 02 U16, Length
//3D U8, Register
Save recorded trajectory ​
Register:62 (0x3E)
00 01 00 02 00 0A 3E 74 65 73 74 2E 74 72 61 6A
Request Description
//00 0A U16, Length
//3E U8, Register
//74 65 73 74 2E 74 72 61 6A U8,Trajectory name (max length:80 Bytes)
e. g. test.traj
00 01 00 02 00 02 3E 00
//00 02 U16, Length
//3E U8, Register
Load recorded trajectory ​
Register:63 (0x3F)
00 01 00 02 00 0A 3F 74 65 73 74 2E 74 72 61 6A
Request Description
//00 0A U16, Length
//3F U8, Register
e. g. test.traj
00 01 00 02 00 02 3F 00
//00 02 U16, Length
//3F U8, Register
Playback recorded trajectory ​
Register:64 (0x40)
00 01 00 02 00 09 40 00 00 00 01 00 00 00 01
Request Description
//00 09 U16, Length
//40 U8, Register
//00 00 00 01 FP32, Cycles of playback
//00 00 00 01 FP32, playback speed
1: 1x speed
2: 2x speed
4: 4x speed
00 01 00 02 00 02 40 00
//00 02 U16, Length
//40 U8, Register
Get the state of recorded trajectory ​
Register:65 (0x41)
00 01 00 02 00 01 41
Request Description
//00 01 U16, Length
//41 U8, Register
00 01 00 02 00 03 41 00 00
//00 03 U16, Length
//41 U8, Register
//00 U8,
0: no read/write
1: loading
2: load success
3: load failed
4: saving
5: save success
6: save failed
Set allow to avoid over speed near some singularities using approximate solutions ​
Register: 66 (0x42)
//Request
00 01 00 02 00 02 42 00
Request Description
//00 02 U16, Length
//42 U8, Register
//00 U8, 0 :Not allow ,1 :allow
//00 02 U16, Length
//42 U8, Register
Get D-H parameters ​
Register: 67 (0x43)
//Request
00 01 00 02 00 01 43
Request Description
//00 01 U16, Length
//43 U8, Register
00 01 00 02 00 72 43 00 00 00 00 00 00 80 85 43 00 00 00 00 00 00 00 00 FD 44 B1 BF 00 00 00 00 DB 0F C9 BF 00 00 00 00 FD 44 B1 3F 00 00 00 00 00 00 00 00 49 BE 90 43 00 00 00 00 00 40 AB 43 DB 0F C9 BF 00 00 9B 42 00 00 00 00 00 00 00 00 DB 0F C9 3F 00 00 00 00 00 00 00 00 00 00 C2 42 DB 0F C9 BF 00 00 98 42 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
//00 01 U16, Transaction ID //00 02 U16, Protocol Identifier //00 72 U16, Length //43 U8, Register //00 U8, State
Note: 4 float parameters per joint
A total of 112 bytes, 28 floating-point data,
only the first 24 floating-point data of the xArm6 are valid data
T2_offset = -atan(284.5/53.5) = -1.3849179 (-79.34995°)
T3_offset = atan(284.5/53.5)+atan(0.3425/0.0775) = 2.7331843 (156.599924°)
a2 = sqrt(284.5^2+53.5^2) = 289.48866
T4_offset = -atan(342.5/77.5) = -1.3482664 (-77.249974°)
a3 = sqrt(77.5^2+342.5^2) = 351.158796
For example: xArm6 SN:XI120204201B02
//J1 d(mm):267 alpha(rad):0 a(mm):0 offset(rad):0
00 00 00 00
00 80 85 43
00 00 00 00
00 00 00 00
//J2 d(mm):0 alpha(rad):-pi/2 a(mm):0 offset(rad):T2_offset
FD 44 B1 BF
00 00 00 00
DB 0F C9 BF
00 00 00 00
//J3 d(mm):0 alpha(rad):0 a(mm):a2 offset(rad):T3_offset
FD 44 B1 3F
00 00 00 00
00 00 00 00
49 BE 90 43
//J4 d(mm):342.5 alpha(rad):-pi/2 a(mm):77.5 offset(rad):0
00 00 00 00
00 40 AB 43
DB 0F C9 BF
00 00 9B 42
//J5 d(mm):0 alpha(rad):pi/2 a(mm):0 offset(rad):0
00 00 00 00
00 00 00 00
DB 0F C9 BF
00 00 00 00
//J6 d(mm):97 alpha(rad):-pi/2 a(mm):76 offset(rad):0
00 00 00 00
00 00 C2 42
DB 0F C9 BF
00 00 98 42
//J7 Null
00 00 00 00
00 00 00 00
00 00 00 00
00 00 00 00
Set D-H parameters ​
Register: 68 (0x44)
00 01 00 02 00 73 44 00 00 00 00 00 00 80 85 43 00 00 00 00 00 00 00 00 FD 44 B1 BF 00 00 00 00 DB 0F C9 BF 00 00 00 00 FD 44 B1 3F 00 00 00 00 00 00 00 00 49 BE 90 43 00 00 00 00 00 40 AB 43 DB 0F C9 BF 00 00 9B 42 00 00 00 00 00 00 00 00 DB 0F C9 3F 00 00 00 00 00 00 00 00 00 00 C2 42 DB 0F C9 BF 00 00 98 42 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Request Description
//00 73 U16, Length
//44 U8, Register
Note:
00 00 00 00
00 80 85 43
00 00 00 00
00 00 00 00
FD 44 B1 BF
00 00 00 00
DB 0F C9 BF
00 00 00 00
FD 44 B1 3F
00 00 00 00
00 00 00 00
49 BE 90 43
00 00 00 00
00 40 AB 43
DB 0F C9 BF
00 00 9B 42
00 00 00 00
00 00 00 00
DB 0F C9 BF
00 00 00 00
00 00 00 00
00 00 C2 42
DB 0F C9 BF
00 00 98 42
//J7 Null
00 00 00 00
00 00 00 00
00 00 00 00
00 00 00 00
//00 U8,Set flag
0: use the set DH parameters, but do not save to the configuration file
1: Use the set DH parameters and save them to the configuration file
2: Use the set DH parameters and delete the configuration file
3: Use the default DH parameters, but do not delete the configuration file
4: Use the default DH parameters and delete the configuration file
00 01 00 02 00 02 44 00
//00 02 U16, Length
//44 U8, Register
Get the currently executing command ​
It needs to be parsed according to different registers
Register: 69 (0x45)
00 01 00 02 00 01 45
Request Description
//00 01 U16, Length
//45 U8, Register
00 01 00 02 00 2B 45 00 17 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C2 B8 B2 3E 58 A0 0B 41 00 00 00 00
//00 2B U16, Length
//45 U8, Register
//17 U8,
Current execution motion instruction register:
0x15: Cartesian linear motion
0x16: Linear motion with arc blending
0x17: P2P joint movement
0x18: joint blending movement
0x19: Back to zero movement
0x1B: arc movement
0x1C: Linear motion in tool coordinate system
0x5C: linear motion of axis angle attitude target
//00 00 00 00 FP32, Joint1=0
//00 00 00 00 FP32, Joint2=0
//00 00 00 00 FP32, Joint3=0
//00 00 00 00 FP32, Joint4=0
//00 00 00 00 FP32, Joint5=0
//00 00 00 00 FP32, Joint6=0
//00 00 00 00 FP32, Joint7=0
//C2 B8 B2 3E FP32, speed=20π/180 rad/s
//58 A0 0B 41 FP32, 500π/180 rad/s²
//00 00 00 00 FP32, motion time=0
Select current data or torque data to report ​
Correspond to the report contents "60~87 Bytes" of TCP ports 30001/30002/30003
Register: 70 (0x46)
00 01 00 02 00 02 46 00
Request Description
//00 02 U16, Length
//46 U8, Register
//00 U8,
value of theoretical joint torque
0: value of theoretical joint torque, unit : Nm
1: value of actual current of servo, unit : A
//00 02 U16, Length
//46 U8, Register
