Modbus RTU Slave: How to trigger Blockly project ​
1. Scenario Description ​
  • Device: xArm Controller (AC1320 or later, AC8520 or later)
  • Firmware: V2.7.104 or later
  • Communication: Modbus RTU
  • Device Role: Slave
  • Target Function: Trigger an Blockly project named 00012.
alt text
2. Mapping Between Coils and CO ​
Modbus Holding Registers AddressDescriptionOther
0030Blockly ProjectThe value stands for the project name
3. Modbus RTU Command Examples (Function Code 0x10) ​
Raw Command Frame (HEX) ​
text
01 10 00 30 00 01 02 00 0C A3 A5
Command Structure Breakdown
text
Slave Address: 01 (1)
Function Code: 10
Start Address: 00 30 (0030)
Number of Registers: 00 01 (1)
Byte Count: 02 (2)
Data Field:
  Address 00 30: 00 0C(UINT16: 12)
CRC: A3 A5
Response Frame (HEX) ​
text
01 10 00 30 00 01 01 C6
text
Function Code: 10
Start Address: 00 30 (48)
CRC: 01 C6
