How to start the Gcode file via Modbus TCP?
Firmware requirements
- Firmware version: V2.4.0+
- UFactory version: V2.4.0+
Holding Registers:
- function code: 0x10
- registers: 0x40
It will only trigger the Gcode file under the modbus_tcp folder.
Example to start 1 Gcode file
Start 1 Gcode file named 00020.
00 01 00 00 00 09 01 10 00 40 00 01 02 00 14- 00 01 00 00: fixed
- 00 09: data length
- 01: ID, fixed
- 10: function code
- 00 40: register address
- 00 01: trigger 1 Blockly project
- 02: data length
- 00 14: Gcode file name
Example to start 2 Gcode files
Start 2 Blockly projects named 00001 and 00032.
00 01 00 00 00 0B 01 10 00 40 00 02 04 00 01 00 32- 00 01 00 00: fixed
- 00 0B: data length
- 01: ID, fixed
- 10: function code
- 00 02: trigger 2 Blockly projects
- 04: data length
- 00 01: Gcode file named 00001.txt
- 00 32: Gcode file named 00050.txt
