Motion Parameter Setting(31-40) ​
Set the jerk of the Cartesian space translation ​
Register:31 (0x1F)
00 01 00 02 00 05 1F 00 00 FA 44
Request Description
//00 05 U16, Length
//1F U8, Register
//00 00 FA 44 FP32, TCP Jerk=2000 mm/s³
00 01 00 02 00 04 1F 00 00 01
Response Description
//00 04 U16, Length
//1F U8, Register
//00 01 U16, The number of commands in the buffer
Set the maximum acceleration of the Cartesian space translation ​
Register:32 (0x20)
00 01 00 02 00 05 20 00 80 BB 45
Request Description
//00 05 U16, Length
//20 U8, Register
//00 80 BB 45 FP32, Maximum acceleration=6000 mm/s²
00 01 00 02 00 04 20 00 00 01
//00 04 U16, Length
//20 U8, Register
//00 01 u16, The number of commands in the buffer
Set the joint space jerk ​
Register:33 (0x21)
00 01 00 02 00 05 21 00 40 1C 46
Request Description
//00 05 U16, Length
//21 U8, Register
//00 40 1C 46 FP32, Jerk=10000 rad/s³
00 01 00 02 00 04 21 00 00 01
//00 04 U16, Length
//21 U8, Register
Set joint space max acceleration ​
Register:34 (0x22)
00 01 00 02 00 05 22 00 00 C8 43
Request Description
//00 05 U16, Length
//22 U8, Register
//00 00 C8 43 FP32, Jerk=10000 rad/s³
00 01 00 02 00 04 22 00 00 01
//00 04 U16, Length
//22 U8, Register
Set TCP offset ​
Register:35 (0x23)
warning
The above operations will terminate the ongoing movement of the robotic arm and clear the cache commands, which is the same as the STOP state.
00 01 00 02 00 19 23 00 00 C8 43 00 00 00 00 00 00 48 43 DB 0F 49 40 00 00 00 00 00 00 00 00
Request Description
//00 19 U16, Length
//23 U8, Register
//00 00 C8 43 FP32, x=400 mm
//00 00 00 00 FP32, y=0 mm
//00 00 48 43 FP32, z=200 mm
//DB 0F 49 40 FP32, roll=π
//00 00 00 00 FP32, pitch=0
//00 00 00 00 FP32, yaw=0
00 01 00 02 00 02 23 10
//00 02 U16, Length
//23 U8, Register
//10 U8, State
Set TCP payload ​
Register:36 (0x24)
00 01 00 02 00 11 24 00 00 80 3F 00 00 C8 43 00 00 00 00 00 00 48 43
Request Description
//00 11 U16, Length
//24 U8, Register
//00 00 80 3F FP32, Payload=1kg
//00 00 C8 43 FP32, Payload center of mass X=400mm
//00 00 00 00 FP32, Payload center of mass Y=0
//00 00 48 43 FP32, Payload center of mass Z=200mm
00 01 00 02 00 02 24 20
//00 02 U16, Length
//24 U8, Register
//20 U8, State
Set collision detection sensitivity (System reset) ​
Register:37(0x25)
warning
//Request
00 01 00 02 00 02 25 04
Request Description
//00 02 U16, Length
//25 U8, Register
//04 U8, Detect sensitivity=4
00 01 00 02 00 02 25 10
//00 02 U16, Length
//25 U8, Register
//10 U8, State
Set teaching sensitivity for manual mode (System reset) ​
Register:38(0x26)
warning
//Request
00 01 00 02 00 02 26 04
Request Description
//00 02 U16, Length
//26 U8, Register
//04 U8, Teach sensitivity=4
00 01 00 02 00 02 26 10
//00 02 U16, Length
//26 U8, Register
//10 U8, State
Delete the current system configuration parameters ​
Register:39 (0x27)
//Request
00 01 00 02 00 01 27
Request Description
//00 01 U16, Length
//27 U8, Register
00 01 00 02 00 02 27 10
//00 02 U16, Length
//27 U8, Register
//10 U8, State
Save the current system configuration parameters ​
Register:40 (0x28)
//Request
00 01 00 02 00 01 28
Request Description
//00 01 U16, Length
//28 U8, Register
00 01 00 02 00 02 28 10
//00 02 U16, Length
//28 U8, Register
//10 U8, State
