websocket API ​
WebsocketAPI is used for UFactory Studio software.
1. Introduction ​
  1. Communication Protocol
  • webSocket:ws://{ip}:18333/ws
  • http/1.1:http://{ip}:18333
2. Flow Chart ​
  • front_end: UI-UFactory Studio
  • Background: encapsulate xArm-Python-SDK
  • Controller
  • Robot
  • private_tcp_protocol: pc-to-controller
  • private_servo_control_protocol: controller-to-servo motor
  • Externals:xArm gripper, xArm vacuum gripper, third-party devices,...
3. Data report ​
After establishing the WebSocket connection, the background will report the real-time status of the robot continually, the data format please check as below:
json
    "type": "report",
    "cmd": "devices_status_keys_report",
    "data": [
        0. "xarm_connected",
        1. "xarm_version",
        2. "xarm_port_name",
        3. "xarm_printed",
        4. "xarm_state",
        5. "xarm_version_number",
        6. "xarm_mode",
        7. "xarm_collision_sensitivity",
        8. "xarm_teach_sensitivity",
        9. "xarm_tcp_load",
        10. "xarm_tcp_offset",
        11. "xarm_world_offset",
        12. "xarm_gravity_direction",
        13. "xarm_paused",
        14. "xarm_type",
        15. "xarm_error_code",
        16. "xarm_warn_code",
        17. "xarm_tcp_pose",
        18. "xarm_joint_pose",
        19. "xarm_axis_angle",
        20. "xarm_limit_acc",
        21. "xarm_limit_velo",
        22. "xarm_current_velo",
        23. "xarm_current_acc",
        24. "xarm_limit_angle_acc",
        25. "xarm_limit_angle_velo",
        26. "xarm_current_angle_velo",
        27. "xarm_current_angle_acc",
        28. "xarm_tcp_jerk",
        29. "xarm_joint_jerk",
        30. "xarm_mtbrake",
        31. "xarm_warn",
        32. "xarm_error",
        33. "xarm_servo_error",
        34. "xarm_is_ready",
        35. "xarm_is_verified",
        36. "xarm_axis",
        37. "config",
        38. "xarm_python",
        39. "xarm_speed_percent",
        40. "xarm_acc_percent",
        41. "xarm_initial_point",
        42. "xarm_position_step",
        43. "xarm_attitude_step",
        44. "xarm_joint_step",
        45. "xarm_end_tool_type",
        46. "xarm_gripper_is_enable",
        47. "gripper_error_code",
        48. "bio_gripper_error_code",
        49. "robotiq_error_code",
        50. "xarm_device_type",
        51. "xarm_mount_degrees",
        52. "current_clients_count",
        53. "xarm_is_connecting",
        54. "core_updated",
        55. "firmware_updated",
        56. "channel",
        57. "xarm_counter_val",
        58. "xarm_quick_access_switch",
        59. "xarm_quick_access",
        60. "xarm_gpio_reset_config",
        61. "xarm_default_tcp_acc",
        62. "xarm_default_joint_acc",
        63. "xarm_cgpio_states",
        64. "xarm_voltages",
        65. "xarm_currents",
        66. "xarm_self_collision_params",
        67. "xarm_quick_copy_switch",
        68. "xarm_run_package_blockly_switch",
        69. "xarm_is_simulation_robot",
        70. "bio_gripper_is_enabled",
        71. "robotiq_is_activated",
        72. "xarm_is_velocity",
        73. "xarm_is_axis_angle",
        74. "xarm_is_robot_arm",
        75. "line_track_error_code",
        76. "xarm_other_tool_type",
        77. "ft_sensor",
        78. "lite6_record_mode",
        79. "lite6_ti2_status",
        80. "reduced_states",
        81. "safe_border_states",
        82. "xarm_end_otherCuboid_param",
        83. "xarm_end_otherCylinder_param",
        84. "joint_exceed_axis",
        85. "xarm_is_show_axis_angle"
        86. "xarm_joint_torque"
        87. "xarm_joint_radian"
        88. "xarm_joint_speed_axis"
        89. "xarm_servoj_speed_axis"
        90. "xarm_motion_is_callback"
The response code please refer to api_code.
