6 Axis Force Torque Sensor(200-212) ​
Get external force detection data of 6 Axis Force Torque Sensor ​
Register:200(0xC8)
//Request
00 01 00 02 00 01 C8
Request Description
//00 01 U16, Length
//C8 U8, Register
00 01 00 02 00 1A C8 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Response Description
//00 1A U16, Length
//C8 U8, Register
//00, 00, 00, 00, 00, 00, 00, 00,00, 00, 00, 00,00, 00, 00, 00,00, 00, 00, 00,00, 00, 00, 00 FP32,
External force detection data:
After filtering, load and offset compensation
Enable/Disable 6 Axis Force Torque Sensor ​
Register:201(0xC9)
//Request
00 01 00 02 00 02 C9 00
Request Description
//00 02 U16, Length
//C9 U8, Register
//00 U8, 0-Disable; 1-Enable
//00 02 U16, Length
//C9 U8, Register
Set the control mode of 6 Axis Force Torque Sensor ​
Register:202(0xCA)
//Request
00 01 00 02 00 02 CA 00
Request Description
//00 02 U16, Length
//CA U8, Register
//00 U8,
control mode
0: non-force mode
1: impedance control mode
2: force control mode
00 01 00 02 00 02 CA 10
//00 02 U16, Length
//CA U8, Register
//10 U8, State
Get the control mode of 6 Axis Force Torque Sensor ​
Register:203(0xCB)
//Request
00 01 00 02 00 02 CB
Request Description
//00 02 U16, Length
//CB U8, Register
00 01 00 02 00 03 CB 00 00
//00 03 U16, Length
//CB U8, Register
//00 U8,
control mode
0: non-force mode
Perform end payload identification ​
Register:204(0xCC)
//Request
00 01 00 02 00 02 CC 00
Request Description
//00 02 U16, Length
//CC U8, Register
//00 U8,
0: 6 Axis Force Torque Sensor identification
1: current identification
00 01 00 02 00 2A CC 00
//00 2A U16, Length Type 0: 00,2A Type 1: 00,12
//CC U8, Register
//00,00,00,00 FP32, 4*n Byte
//00,00,00,00 ...
//00,00,00,00
Identification result
Type=0: N=10.
[weight(kg), Cx, Cy, Cz(mm), Fx0, Fy0, Fz0(N), Tx0, Ty0, Tz0(Nm)]
Type=1: N=4.
[weight(kg), offset_Cx, offset_Cy, offset_Cz(mm)]
Set the payload and offset of 6 Axis Force Torque Sensor ​
Register:205(0xCD)
00 01 00 02 00 29 CD 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Request Description
//00 29 U16, Length
//CD U8, Register
//00 00 00 00 FP32, weight: kg
//00 00 00 00 FP32, Cx: mm
//00 00 00 00 FP32, Cy: mm
//00 00 00 00 FP32, Cz: mm
//00 00 00 00 FP32, Fx: mm
//00 00 00 00 FP32, Fy: mm
//00 00 00 00 FP32, Fz: mm
//00 00 00 00 FP32, Tx: mm
//00 00 00 00 FP32, Ty: mm
//00 00 00 00 FP32, Tz: mm
00 01 00 02 00 02 CD 00
//00 02 U16, Length
//CD U8, Register
Set the current state as the zero point of 6 Axis Force Torque Sensor ​
Register:206(0xCE)
//Request
00 01 00 02 00 01 CE
Request Description
//00 01 U16, Length
//CE U8, Register
00 01 00 02 00 02 CE 00
//00 02 U16, Length
//CE U8, Register
Set all impedance control parameters of 6 Axis Force Torque Sensor ​
Register:207(0xCF)
00 01 00 02 00 50 CF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Request Description
//00 50 U16, Length
//CF U8, Register
//00 U8,
0: Base coordinate
1: Tool coordinate
//00 00 00 00 00 00 U8,
1: the corresponding direction will produce impedance
//00 00 00 00 FP326 , 00,00,00,00 00,00,00,00 00,00,00,00 00,00,00,00 00,00,00,00 M => [Mx, My,Mz, Mr, Mp, My]
Equivalent mass(xyz): 0.02~1.0(kg)
Moment of inertia(rpy): 0.0001~0.01(kg
m^2)
//00 00 00 00 FP32*6 , 00,00,00,00 00,00,00,00 00,00,00,00 00,00,00,00 00,00,00,00 Stiffness coefficient.
K => [kx, ky, kz, kr, kp, ky]
xyz: 0~2000(N/m)
rpy: 0~20(Nm/rad)
//00 00 00 00 FP32*6 , 00,00,00,00 00,00,00,00 00,00,00,00 00,00,00,00 00,00,00,00 Damping coefficient
00 01 00 02 00 02 CF 00
//00 02 U16, Length
//CF U8, Register
Set PID parameter of 6 Axis Force Torque Sensor ​
Register:208(0xD0)
00 01 00 02 00 61 D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Request Description
//00 61 U16, Length
//D0 U8, Register
//00 00 00 00 FP32*6, 00,00,00,00 00,00,00,00 00,00,00,00 00,00,00,00 00,00,00,00 Proportional gain: KP
Kp[i]: 0~0.05
//00 00 00 00 FP32*6, 00,00,00,00 00,00,00,00 00,00,00,00 00,00,00,00 00,00,00,00 Integral gain: KI
KI[i]: 0~0.0005
//00 00 00 00 FP32*6, 00,00,00,00 00,00,00,00 00,00,00,00 00,00,00,00 00,00,00,00 Differential gain: KD
KD[i]: 0~0.05
//00 00 00 00 FP32*6, 00,00,00,00 00,00,00,00 00,00,00,00 00,00,00,00 00,00,00,00 Maximum TCP speed along each axis
VMAX[i]: 0~200(mm/s)
00 01 00 02 00 02 D0 00
//00 02 U16, Length
//D0 U8, Register
Set force control parameter of 6 Axis Force Torque Sensor ​
Register:209(0xD1)
00 01 00 02 00 38 D1 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Request Description
//00 38 U16, Length
//D1 U8, Register
//00 U8,
0: Base coordinate
1: Tool coordinate
//00 00 00 00 00 00 U8*6,
1: the corresponding direction can be controlled by force
//00 00 00 00 FP32*6, 00,00,00,00 00,00,00,00 00,00,00,00 00,00,00,00 00,00,00,00 F => [Fx, Fy, Fz, Fr, Fp, Fy]
(F[i]: The arm adjusts its position along the corresponding axis to achieve the specified force torque)
Fx: -150~150 (N)
Fy: -150~150 (N)
Fz: -200~200 (N)
Fr: -4~4(Nm)
Fp: -4~4(Nm)
Fy: -4~4(Nm)
//00 00 00 00 FP32*6, 00,00,00,00 00,00,00,00 00,00,00,00 00,00,00,00 00,00,00,00 (Maximum TCP speed along each axis)
00 01 00 02 00 02 D1 10
//00 02 U16, Length
//D1 U8, Register
Set MKB parameter under impedance control mode of 6 Axis Force Torque Sensor ​
Register:210(0xD2)
00 01 00 02 00 49 D2 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Request Description
//00 49 U16, Length
//D2 U8, Register
//00 00 00 00 FP326, 00,00,00,00 00,00,00,00 00,00,00,00 00,00,00,00 00,00,00,00 M => [Mx, My,Mz, Mr, Mp, My]
m^2)
//00 00 00 00 FP32*6, 00,00,00,00 00,00,00,00 00,00,00,00 00,00,00,00 00,00,00,00 Stiffness coefficient.
xyz: 0~2000(N/m)
rpy: 0~20(Nm/rad)
//00 00 00 00 FP32*6, 00,00,00,00 00,00,00,00 00,00,00,00 00,00,00,00 00,00,00,00 Damping coefficient
00 01 00 02 00 02 D2 00
//00 02 U16, Length
//D2 U8, Register
Set impedance control parameter of 6 Axis Force Torque Sensor ​
Register:211(0xD3)
00 01 00 02 00 08 D3 00 00 00 00 00 00 00
Request Description
//00 08 U16, Length
//D3 U8, Register
//00 U8,
0: Base coordinate
1: Tool coordinate
//00 00 00 00 00 00
00 01 00 02 00 02 D3 00
//00 02 U16, Length
//D3 U8, Register
Get all feedback data of 6 Axis Force Torque Sensor ​
Register:212(0xD4)
00 01 00 02 00 01 D4
Request Description
//00 01 U16, Length
//D4 U8, Register
00 01 00 02 00 1A D4 00 00 00 00 08 03 E8 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
//00 1A U16, Length
//D4 U8, Register
//00 U8, Control mode
//00 U8, Enable state
//00 U8, Type
//08 U8, ID
//03, E8 U16, Frequency
//00,00,00,00 FP32, Weight
//00,00,00,00 FP32, Reserve
//00,00,00,00 FP32, 00,00,00,00 00,00,00,00 Centroid
//00,00,00,00 FP32*6, offset 00,00,00,00 00,00,00,00 00,00,00,00 00,00,00,00 00,00,00,00
//00
Coordinate of impedance control mode
//00,00,00,00,00,00 FP32*6, Impedance control vector
//00,00,00,00 FP32, 00,00,00,00 00,00,00,00 00,00,00,00 00,00,00,00 00,00,00,00 Equivalent mass and Moment of inertia
//00,00,00,00 FP32*6, 00,00,00,00 00,00,00,00 00,00,00,00 00,00,00,00 00,00,00,00 Stiffness coefficient
//00,00,00,00 FP32*6, 00,00,00,00 00,00,00,00 00,00,00,00 00,00,00,00 00,00,00,00 Damping coefficient
//00 U8, Coordinate of force control mode
//00,00,00,00,00,00 FP32, Force Control vector
//00,00,00,00 FP32*6, 00,00,00,00 00,00,00,00 00,00,00,00 00,00,00,00 00,00,00,00 Force vector
//00,00,00,00 FP32*6, 00,00,00,00 00,00,00,00 00,00,00,00 00,00,00,00 00,00,00,00 Reserve
//00,00,00,00 FP32*6, 00,00,00,00 00,00,00,00 00,00,00,00 00,00,00,00 00,00,00,00 KP: Proportional gain
//00,00,00,00 FP32*6, 00,00,00,00 00,00,00,00 00,00,00,00 00,00,00,00 00,00,00,00 KI: Integral gain
//00,00,00,00 FP32*6, 00,00,00,00 00,00,00,00 00,00,00,00 00,00,00,00 00,00,00,00 KD: Differential gain
//00,00,00,00 FP32*6, 00,00,00,00 00,00,00,00 00,00,00,00 00,00,00,00 00,00,00,00 Max TCP speed vector
