Get Motion Information(41-50) ​
Get the current Cartesian position of the robot ​
Register:41(0x29)
00 01 00 02 00 01 29
Request Description
//00 01 U16, Length
//29 U8, Register
00 01 00 02 00 1A 29 10 43 00 4F 43 B4 CE 18 3A 3A 00 E0 42 DB 0F 49 40 FD AD 80 B6 7C D9 20 37
Response Description
//00 1A U16, Length
//29 U8, Register
//10 U8, State
//43 00 4F 43 FP32, x= 207mm
//B4 CE 18 3A FP32, y=0 mm
//3A 00 E0 42 FP32, z=112 mm
//DB 0F 49 40 FP32, roll=π
//FD AD 80 B6 FP32, pitch=0
//7C D9 20 37 FP32, yaw=0
Get the current joint position of the robot ​
Register:42 (0x2A)
00 01 00 02 00 01 2A
Request Description
//00 01 U16, Length
//2A U8, Register
00 01 00 02 00 1E 2A 00 92 0A 86 3F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
//00 1E U16, Length
//2A U8, Register
//92 0A 86 3F FP32, Joint1=1.0471 rad
//00 00 00 00 FP32, Joint2=0 rad
//00 00 00 00 FP32, Joint3=0 rad
//00 00 00 00 FP32, Joint4=0 rad
//00 00 00 00 FP32, Joint5=0 rad
//00 00 00 00 FP32, Joint6=0 rad
//00 00 00 00 FP32, Joint7=0 rad
Get the solution of the inverse kinematics ​
Register:43 (0x2B)
00 01 00 02 00 19 2B 00 00 C8 43 00 00 00 00 00 00 48 43 DB 0F 49 40 00 00 00 00 00 00 00 00
Request Description
//00 19 U16, Length
//2B U8, Register
//00 00 C8 43 FP32, x=400 mm
//00 00 00 00 FP32, y=0 mm
//00 00 48 43 FP32, z=200 mm
//DB 0F 49 40 FP32, roll=π rad
//00 00 00 00 FP32, pitch=0 rad
//00 00 00 00 FP32, yaw=0 rad
00 01 00 02 00 1E 2B 00 D8 C8 B2 A4 0A 86 A7 3D B1 22 24 BF F2 A9 3C 8A EF 31 0F 3F D8 C8 B2 A4 00 00 00 00
//00 1E U16, Length
//2B U8, Register
//D8 C8 B2 A4 FP32, J1=0 rad
//0A 86 A7 3D FP32, J2=0.081803 rad
//B1 22 24 BF FP32, J3=-0.641152 rad
//F2 A9 3C 8A FP32, J4=0 rad
//EF 31 0F 3F FP32, J5=0.5593 rad
//D8 C8 B2 A4 FP32, J6=0 rad
//00 00 00 00 FP32, J7=0 rad
Get the solution of the forward kinematics ​
Register:44 (0x2C)
00 01 00 02 00 1D 2C 92 0A 86 3F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Request Description
//00 1D U16, Length
//2C U8, Register
//92 0A 86 3F FP32, Joint1= π/3 rad
00 01 00 02 00 1A 2C 00 FF FF CE 42 6B 44 33 43 00 00 E0 42 DB 0F 49 C0 00 00 00 80 92 0A 86 3F
//00 1A U16, Length
//2C U8, Register
//FF FF CE 42 FP32, x=103.5 mm
//6B 44 33 43 FP32, y=179.27 mm
//00 00 E0 42 FP32, z=112 mm
//DB 0F 49 C0 FP32, roll=-π rad
//00 00 00 80 FP32, pitch=-0 rad
//92 0A 86 3F FP32, yaw=-π/3 rad
Check the limit of joint space ​
Register:45 (0x2D)
00 01 00 02 00 1D 2D 92 0A 86 3F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Request Description
//00 1D U16, Length
//2D U8, Register
//92 0A 86 3F FP32, joint1=π/3
//00 00 00 00 FP32, joint2=0
//00 00 00 00 FP32, joint3=0
//00 00 00 00 FP32, joint4=0
//00 00 00 00 FP32, joint5=0
//00 00 00 00 FP32, joint6=0
//00 00 00 00 FP32, joint7=0
00 01 00 02 00 03 2D 00 00
//00 03 U16, Length
//2D U8, Register
//00 U8, 1 :Collision occurs , 0 :No collision occurs
Set TCP speed limit in Reduced Mode ​
Register:47 (0x2F)
00 01 00 02 00 05 2F 00 00 C8 43
Request Description
//00 05 U16, Length
//2F U8, Register
//00 00 C8 43 U8, Max TCP speed=400 mm/s
00 01 00 02 00 02 2F 00
//00 02 U16, Length
//2F U8, Register
Set Joint speed limit in Reduced Mode ​
Register:48 (0x30)
00 01 00 02 00 05 30 00 00 80 3F
Request Description
//00 05 U16, Length
//30 U8, Register
//00 00 C8 43 U8, Max joint speed=1.0 rad/s
00 01 00 02 00 02 30 00
//00 02 U16, Length
//30 U8, Register
Get the state of the Reduced Mode ​
Register:49 (0x31)
00 01 00 02 00 01 31
Request Description
//00 01 U16, Length
//31 U8, Register
00 01 00 03 00 03 31 00 00
//00 03 U16, Length
//31 U8, Register
//00 U8, 0 means OFF; 1 means ON
Set the state of the Reduced Mode ​
Register:50 (0x32)
00 01 00 02 00 02 32 00
Request Description
//00 02 U16, Length
//32 U8, Register
//00 U8, 0: turn off Reduced Mode 1: turn on Reduced Mode
00 01 00 03 00 02 32 00
//00 02 U16, Length
//32 U8, Register
