xarm_api_code ​
xArmSDK API code description ​
  • -12: run blockly app exception
  • -11: convert blockly app to pythen exception
  • -9: emergency stop
  • -8: out of range
  • -7: joint angle limit
  • -6: cartesian pos limit
  • -5: revesed, no use
  • -4: command is not exist
  • -3: revesed, no use
  • -2: xArm is not ready, may be the motion is not enable or not set state
  • -1: xArm is disconnect or not connect
  • 0: success
  • 1: there are errors that have not been cleared
  • 2: there are warnings that have not been cleared
  • 3: get response timeout
  • 4: tcp reply length error
  • 5: tcp reply number error
  • 6: tcp protocol flag error
  • 7: tcp reply command and send command do not match
  • 8: send command error, may be network exception
  • 9: state is not ready to move
  • 10: the result is invalid
  • 11: other error
  • 12: parameter error
  • 20: host id error
  • 21: modbus baudrate not supported
  • 22: modbus baudrate not correct
  • 23: modbus reply length error
  • 31: trajectory read/write failed
  • 32: trajectory read/write timeout
  • 33: playback trajectory timeout
  • 41: wait to set suction cup timeout
  • 80: linear track has error
  • 81: linear track sci is low
  • 82: linear track is not init
  • 100: wait finish timeout
  • 101: too many consecutive failed tests
  • 102: end effector has error
  • 103: end effector is not enabled
Controller Warn Code ​
  • 11: uxbux que is full
  • 13: the instruction does not exist
  • 14: command has no solution
  • 15: modbus cmd full
Controller Error Code ​
  • 1: The Emergency Stop Button is pushed
  • 2: The Emergency IO of the Control Box is triggered
  • 3: The Emergency Stop Button of the Three-state Switch is pressed
  • 10: Servo motor error
  • 11: Servo motor 1 error
  • 12: Servo motor 2 error
  • 13: Servo motor 3 error
  • 14: Servo motor 4 error
  • 15: Servo motor 5 error
  • 16: Servo motor 6 error
  • 17: Servo motor 7 error
  • 18: Force Torque Sensor Communication Error
  • 19: End Module Communication Error
  • 21: Kinematic Error
  • 22: Self-Collision Error
  • 23: Joints Angle Exceed Limit
  • 24: Speed Exceeds Limit
  • 25: Planning Error
  • 26: Linux RT Error
  • 27: Command Reply Error
  • 28: End Module Communication Error
  • 29: Other Errors
  • 30: Feedback Speed Exceeds limit
  • 31: Collision Caused Abnormal Current
  • 32: Three-point drawing circle calculation error
  • 33: Controller GPIO error
  • 34: Recording Timeout
  • 35: Safety Boundary Limit
  • 36: The number of delay commands exceeds the limit
  • 37: Abnormal movement in Manual Mode
  • 38: Abnormal Joint Angle
  • 39: Abnormal Communication Between Master and Slave IC of Power Board
  • 40: No IK available
  • 50: Six-axis Force Torque Sensor read error
  • 51: Six-axis Force Torque Sensor set mode error
  • 52: Six-axis Force Torque Sensor set zero error
  • 53: Six-axis Force Torque Sensor is overloaded or the reading exceeds the limit
  • 110: Robot Arm Base Board Communication Error
  • 111: Control Box External 485 Device Communication Error
Servo Error Code ​
  • 10: Current Detection Error
  • 11: Joint Current Overlimit
  • 12: Joint Speed Overlimit
  • 14: Position Command Overlimit
  • 15: Joints Overheat
  • 16: Encoder Initialization Error
  • 17: Single Ring Encoder Error
  • 18: Multi-turn Encoder Error
  • 19: Low Battery Voltage
  • 20: Driver IC Hardware Error
  • 21: Driver IC Initialization Error
  • 22: Encoder Configuration Error
  • 23: Large Motor Position Deviation
  • 26: Joint N Positive Overrun
  • 27: Joint N Negative Overrun
  • 28: Joint Commands Error
  • 33: Drive Overloaded
  • 34: Motor Overload
  • 35: Motor Type Error
  • 36: Driver Type Error
  • 39: Joint Voltage Overload
  • 40: Joint Voltage Insufficient
  • 49: EEPROM Read and Write Error
  • 52: Motor Angle Initialization Error
Gripper Error Code ​
  • 9: Gripper Current Detection Error
  • 11: Gripper Current Overlimit
  • 12: Gripper Speed Overlimit
  • 14: Gripper Position Command Overlimit
  • 15: Gripper EEPROM Read and Write Error
  • 20: Gripper Driver IC Hardware Error
  • 21: Gripper Driver IC Initialization Error
  • 23: Gripper Large Motor Position Deviation
  • 25: Gripper Command Over Software Limit
  • 26: Gripper Feedback Position Software Limit
  • 33: Gripper Drive Overloaded
  • 34: Gripper Motor Overload
  • 36: Gripper Driver Type Error
Bio Gripper Error Code ​
  • 11: BIO Gripper Current Overlimit
  • 12: The object slipped from the BIO Gripper
Linear Motor Error Code ​
  • 10: Linear Motor Current Detection Error
  • 11: Linear Motor Current Overlimit
  • 12: Linear Motor Speed Overlimit
  • 13: Linear Motor Large Motor Position Deviation
  • 14: Linear Motor Position Command Overlimit
  • 20: Linear Motor Driver IC Hardware Error
  • 21: Linear Motor Driver IC Initialization Error
  • 25: Linear Motor Command Over Software Limit
  • 26: Linear Motor Feedback Position Software Limit
  • 33: Linear Motor Drive Overloaded
  • 34: Linear Motor Motor Overload
  • 35: Linear Motor type error
  • 36: Linear Motor Driver Type Error
  • 39: Linear Motor over voltage
  • 40: Linear Moter undervoltage
  • 49: Linear Motor EEPROM Read and Write Error
Six-axis Force Torque Sensor Error Code ​
  • 64: Six-axis Force Torque Sensor Communication Failure
  • 65: The Data Collected by the Six-axis Force Torque Sensor is Abnormal
  • 66: Six-axis Force Torque Sensor X-direction Torque Exceeds Limit
  • 67: Six-axis Force Torque Sensor Y-direction Torque Exceeds Limit
  • 68: Six-axis Force Torque Sensor Z-direction Torque Exceeds Limitrection
  • 69: Six-axis Force Torque Sensor Tx Torque Exceeds Limit
  • 70: Six-axis Force Torque Sensor Ty direction Torque Exceeds Limit
  • 71: Six-axis Force Torque Sensor Tz direction Torque Exceeds Limit
  • 73: Six-axis Force Torque Sensor Failed to Initialize
